I need to make a housewarming present for a friend, and I have always fancied making a table lamp so plan to kill two birds with one stone.
It will be fairly simple I think, but I need to see what style of furniture they like so it compliments. I am thinking it will be 200 diameter at its widest and about 300mm tall. The width is about the capacity of my baby lathe.
It needs a hole drilling through the length of the blank (endgrain), and "if" it wanders slightly, will then turn it between centres using the hole as the centre of the blank and true it up again. I know that I will need to buy some bits, but would ideally keep this to a minimum (ie not spend £50 on the record long boring kit). My lathe has a through tailstock and I think that somewhere I have a hollow live centre. I have a good chuck with big dovetail jaws, a faceplate ring and a couple of different drive centres (although not one that sticks in a drilled hole). I know that I dont have an auger or a long drill bit.
Would I be better to drill it off the lathe, or try to drill on it? Any hints or tips?
I make a present or two a year, often pepper mills. I can see this kit being used again, but it is going to be very occasionally. Ab 8mm auger bit at UK drills (8.0mm x 460mm) is £3.24 which may sway the decision a bit!
