MikeG.
I started off by calling the wooden plane maestro himself, Philly, and getting a nice blade made and sent. He was very helpful indeed..........thanks again Phil!! I asked for a 45 degree bevel, and the blade is 3mm thick.
Then I grabbed some offcuts of spalted sycamore:
and cut some shapes:
Some of you might remember a set of bedside tables I ballsed up. When I cut the walnut legs off, I set them aside for the day I would need to make a scraper plane (!! Oh Yeah?!)
Then I glued all the bits together........some might have spotted this image in another thread:
I have missed a photo or two here......never mind. I sliced up the walnut sandwich, and cleaned it all up to give a thin veneer of walnut on my sycamore. Then marked out the main lump of timber:
Did some cutting and chiselling:
These are all the main bits made.......the blade will lean forward by 5 degrees at the top:
Stuck it together:
I picked just abnout the least spalted bits of my sycamore stock I could find, but it still isn't very easy to work. Next step was a whole lot of cleaning up and shaping:
Another photo or 2 missing........
I made a temporary wedge, pushed it all together, and gave it a try. With a bit of mucking around with the setting, which I find tremendously difficult at the moment, it worked beautifully. You can see some shavings of oak here.
One coat of oil, so far....
Remember, this is a tool, not an art object! Judge it on the scrapings and ease of use........and on that criteria, I think it will be fine once I have learnt how to get the bloody wedge out!! Saying that, there is a proper wedge under construction at the moment......I just need to attach a shackle hitch to it so that I can use a winch to remove the damn thing........
I was going to turn up a couple of knobs for this, but it feels so nice as it is that I changed my mind. That, and the fact that I would be accused of heading off down 2 different slopes in the course of one project.
5 hours construction time........(+1 hour to load onto UKW).
Mike
Stuck it together:
Mike
