What are you bandsaw users using to support work while you cut it on your machine. Something like this, or some other solution?
http://www.rutlands.co.uk/sp+woodworkin ... kota+dkk15
woodpig":3d97sz21 said:As an example. I need to cut a 6 inch wide strip off the end of a 6' x 2' sheet of 9mm ply. I'll have to cut a slightly larger strip off the end with a hand saw and then trim to size on the bandsaw. I did cut a similar piece from a 4' x 2' sheet the other day all on the bandsaw but it was a bit tricky and I had to stack up some boxes to "catch" the piece I cut off.
woodpig":27c2vm1c said:As an example. I need to cut a 6 inch wide strip off the end of a 6' x 2' sheet of 9mm ply. I'll have to cut a slightly larger strip off the end with a hand saw and then trim to size on the bandsaw. I did cut a similar piece from a 4' x 2' sheet the other day all on the bandsaw but it was a bit tricky and I had to stack up some boxes to "catch" the piece I cut off.
Random Orbital Bob":2d97asi3 said:You're a veritable treasure trove of quirky, simple but effective ideas like that Steve. Where did you first learn them?
