- Joined
- 19 Mar 2007
- Messages
- 5,295
- Reaction score
- 411
I'm not sure where this should go, but as it is a general type of thingy here it is. Appologies to anyone who knows just how to suck eggs..
This is probably aimed primaraly at us blokes, but for the more handy fairer *** too?
If you are fed up with having a little tube of superglue that you can't use after you have had it for a little while then here is a tip for you. It won't endire you to the OH, but it will save yer expensive glue.
Keep it in the fridge. Simple init. Just find a corner where it won't stick out (sorry about the pun, errrr, no I ain't) and store it with the top upwards. That way the glue won't block yer little hole and it's ready to use when you want it. It will last for a heck of a lot longer than the stuff you keep on a shelf in a cupboard.
Also, when you come to stick yer family treasures back together it will stick much better if the 2 surfaces are damp and if it's a small surface and you lick yer finger and damp the surfaces with that it's even better. After all it was designed to stick soldiers together when they got shot up and blown apart in the war in Vietnam.
Not-a-lot-a-people-know-that....
