bp122
Expert at Jibber-Jabber
Hi All
I am attempting a Novelty project as an Xmas present for my wife.
It is basically a 250 x 250mm box, which is about 70mm deep. It will be wall hung (imagine a deep boxy photo frame, if you will) with a glass (or perspex) front and a hard back (hardboard or thinner MDF)
It will be painted in dark or navy blue.
My question is how to get the glass / prespex secured on the front side?
The following options I have thought so far are:
1. Groove the two sides and the bottom panels and slide the glass from the top
2. Recess the finished frame front with a router and then place the glass and make a face frame to cover up the edges
I would prefer if the screws didn't show anywhere - planning to do it with just glue at the moment.
I would like to have the option of replacing the glass in the future, just in case.
Problems I see with option 1 is the dust and dirt will come through the opening at the top through which the glass is slid in. And sliding the glass through one of the sides shows the opening.
With option 2, I can't glue the face frame to the rest of the box. as it won't be removable, using fasteners will result in them being visible, which wouldn't be preferable.
Any suggestions on how I can solve this? or are there any special techniques I am unaware of that I should consider?
My skill level is basic beginner and the tools I have are a table saw, router, drill press and hand tools.
Thanks in advance
Thanks in advance
