SketchUp Guru
24 January, 2007 The following tutorial was written prior to the release of SketchUp V6. With the most current version of SketchUp a few detail things have changed. Rather than edit the entire thread, I will make note of a few of those things here. I'm doing this based on memory so pardon my if I miss something.
In SU5Pro/GSU--Construction Geometry (Lines and points). In GS6/GSU6Pro--Guides.
In SU5Pro/Early versions of GSU--Hold Ctrl with Move or Rotate tool to copy. Later versions of GSU/GSU6/GSU6Pro--Press and release Ctrl with Move or Rotate tool to copy. It's a toggle function now. This applies to several other tools including the Tape Measure and Protractor tools.
John McM made a suggestion the other day for a step by step demo of sorts. I've come up with a fairly simple armoire design that we'll "build". Attached is a drawing I made of the whole thing. This drawing would be the sort of quick thing you'd make to use for communicating with a client (" 'Er indoors"). There are no groups or components and the thing is entirely hollow. No internal details have been drawn yet. At this point it would be simple enough to make changes. Does she want it wider or taller, 3 drawers instead of one. That sort of thing. Once we have approval from the client, it is time to move on to a detailed version to use for shop drawings. When we're finished it sould be possible to head out to the shop and start making saw dust.
The benefit to starting this way is that you have little time invested in something that might get changed dramatically before the project is really under way. Who knows, she might decide that it should be a tire swing instead of an armoire. :roll:
The next installment will cover construction of a single part of the armoire. We'll get that part finished before we move on to the next part.
Does this sound like what you had in mind John?
