MorrisWoodman12
I've a strange problem with my plumbing so I thought I'd ask the vastly knowledgable collective for any ideas. Thanks in advance.
I live in a house built in 1970. Two years ago, after we moved in, the boiler was replaced along with removing the header tank, putting in a Thermstore hot water tank and generally updating everything to a sealed hotwater/central heating delivery system. Just about all the time we use an immersion heater to heat the water in the tank (about an hour each morning) and only use the boiler for central heating.
A few weeks ago we had the stop cock replaced as it was original and weeping. This increased the flow of water into the system as seen at all the taps. Last week we found the bottom of the boiler had water dripping from it and covering all the pipework and the floor. This was then repeated every night even though the boiler was off and occasionally we would look in the middle of the night and see it had occurred before the immersion heater turned on. Then a couple of nights ago I was awake and heard a sound almost mildly explosive in nature followed by a rushing water sound lasting about 4 seconds. This was repeated about a minute or two later. Water again is all over the boiler and pipework – it wasn’t an hour or so earlier. I found water dripping through a sight gauge (hope that’s the right term) and subsequently wrapped a towel around it. On two subsequent nights the towel has been wet and the floor and pipework remained dryish.
Before/above the sight gauge the pipe splits into two: one side to a temperature and pressure relief valve; the other back into the boiler.
We have also noticed the hot water is scaldingly hot since the problem started.
Does anyone have any ideas?
