RichardG
If at first you don’t succeed have a cup of tea.
I made a couple of large cupboard doors (1.8m) to try and match the existing pine Victorian doors in the house. Didn’t have much choice of wood during lockdown, stock issues and inability to hand sort. In the end I ordered a load of pine v-groove tongue and groove matching and picked the best to make the doors after conditioning the timber for 3 weeks inside the house. Now the doors are made and hung one door has really started to twist, I was expecting some twisting but one door is quite bad, about 25mm.
I‘ve clamped the door to try and take out the twist, which has helped, but was wondering about steaming using a wall paper stripper or spray wetting the wood and then let dry again? Alternatively perhaps a threaded tension bar corner to corner to pull out the twist?
At some point I’ll go searching reclamation yards to see if I can find a pair of old doors I can cut down and use but that could be sometime away and not always successful.
Any other suggestions, including throwing in in the wood burner!!
