Hi all.
I've always found the process of cuting mitres in moulded stile and rail joints very time consuming. As part of a cabinet I'm currently making I thought of documenting my process. Nothing really new here, it's basically an hand tool task. If I'me lucky I can finish one in about 15 minutes, but most of the time it takes much more: Ive got to do several iterations before all fits in nicely. And I'm talking about moulding on just the front side and offset shoulders so I can avoid cutting mitres on the back. This way only 8 surfaces must meet (2 shoulders and 2 mitres on the stile and on the rail).
It's a helluva time for just an humble joint.
How would you do this in production?
I'd appreciate inputs as to speeding up this process: no cheating like applying beads afterwards or scribing joints (you cannot scribe joints whose moulds aren't strictly decreasing curves).
Now here's my process:
First the tenon is assembled the normal way, as if there was no moulding at all
A square is used to mark on the stile the locations where the mouldings will intersect.
here's the result:
then I chop the waste in the stile with a chisel. the bead groove will help in registering the chisel for paring
A 45 deg template is used to cut the mitres. I make several cuts removing little material in each pass.This avoids tearing out the unsupported portion of the bead right above the groove.
I finish the cut with a chisel plane:
the finished stile:
using the same process for the tenon:
the finished tenon:
didn't get a good fit for the first time and had to remove a bit from the back shoulder.
The end result: front:
and back:
Thanks for looking.
![p1010003.jpg](https://proxy.imagearchive.com/619/619f1b06b64b1600bbf450a35328166a.jpg)
![p1010004.jpg](https://proxy.imagearchive.com/fb3/fb37ca52b4e6f009e8ea4780e54db46f.jpg)
here's the result:
![p1010006.jpg](https://proxy.imagearchive.com/74a/74a7ecd35838154c47aa5a6e8e186e6a.jpg)
![p1010007.jpg](https://proxy.imagearchive.com/4d1/4d1bc2d880b2f09bef02b2353aa1b1a9.jpg)
![p1010008.jpg](https://proxy.imagearchive.com/820/820f57025b487396c73ddd6db543e946.jpg)
![p1010009.jpg](https://proxy.imagearchive.com/c3d/c3d6deaadad2a5d022edc7c59c098479.jpg)
the finished stile:
![p1010010.jpg](https://proxy.imagearchive.com/edb/edb3d91f646b460645a323157eb374fb.jpg)
![p1010011.jpg](https://proxy.imagearchive.com/a1e/a1e4498e78e76c62a25ad9f231859397.jpg)
the finished tenon:
![p1010012.jpg](https://proxy.imagearchive.com/78f/78fc4e147f2ada745de3f34e3cbf4dca.jpg)
![p10100131.jpg](https://proxy.imagearchive.com/84e/84e69c61d6af4b26986bf67182a2bafc.jpg)
![p1010014.jpg](https://proxy.imagearchive.com/9b4/9b47be8e423134e5788c646a1ca1930a.jpg)
and back:
![p1010015.jpg](https://proxy.imagearchive.com/850/850dbbf1072503319f33d3241755f53a.jpg)
Thanks for looking.
