Steve Maskery":lh6ifn6b said:Just as long as you come and bow at the altar.
S
I read that three times to make sure it wasn't the other way round. I didn't think the church couldn't be so open minded :shock:
Good work Steve, keep it up
S
xy mosian":wk6oa7ju said:Steve Maskery":wk6oa7ju said:I forgot to say, I think I have cocked up on the ceiling electrics. I do think it is a good idea to have some power up there, but I should have put the switches in the wall, not just use switched sockets on the ceiling. It means I'm going to have to poke about with a stick to switch stuff on and off!
Idiot.
S
Is there a chance of adding a 13A Pull Switch next to the socket to isolate it, effectively switching it. If you don't like the idea of a toggle, just out of reach, then a rigid loop could be added to use with a shepherds crook, or similar.
xy
Steve Maskery":ncvil8pw said:I forgot to say, I think I have cocked up on the ceiling electrics. I do think it is a good idea to have some power up there, but I should have put the switches in the wall, not just use switched sockets on the ceiling. It means I'm going to have to poke about with a stick to switch stuff on and off!
Idiot.
S
I got them from Yesss Electrical. They were about 60 quid each IIRC. You don't get much for your money TBH. I forget the make, I'll have to go down and have a look in daylight. I still have the boxes.Wizard9999":r9rl1kd2 said:Steve
The lights look really good. What are they and where did you get them?
Terry.
Well done Steve - that's got to be a great motivator!!Steve Maskery":1n0ek672 said:.........and I can get my tablesaw in.....
Wizard9999":prmch731 said:Steve
Terry.
