TheTiddles":23g47cm7 said:Jacob":23g47cm7 said:TheTiddles":23g47cm7 said:...
So there you go, I wonder what reaction there will be but I think I already know.
yawn?
marcros":1tyy8vee said:TheTiddles":1tyy8vee said:So there you go, I wonder what reaction there will be but I think I already know.
yawn?
Is there a need to be so condescending towards other forum users???TheTiddles":17d591gm said:Jacob":17d591gm said:Don't know anything about it except that steam is hotter than boiling water, which maybe makes the difference.
ahahahahaha, that's one of the stupidest things you've ever said and let's be honest, you've come out with a lot.
Steam could be hotter if it's pressurised, but so would the water, e.g. a pressure cooker.
It probably is the temperature that makes the wood soften along with being damp but you have to have a method of transferring the heat from the source to the wood. Air isn't great at transferring heat, better than nothing obviously, but water has much more ability to absorb heat and therefore carry it from the source to the wood.
Aidan
I'm not interested in all the shenanigans going on about pressurised this or that, supersteam, or whatever, but I think you've just about summarised what happens Aidan, but I'll add a bit to it.TheTiddles":29gbdauh said:It probably is the temperature that makes the wood soften along with being damp but you have to have a method of transferring the heat from the source to the wood. Aidan
Yes well done!TheTiddles":3lpapynb said:....
PV=cT or PV/T=c as our such learned chum says.
Wrong again. Once the water vapour has separated from the water it can be heated (depending on the configuration of the apparatus) to any temperature, but still remain at atmospheric pressure. Look at the equation and you might be able to work it out for yourself, but I doubt it.........The only way to increase the temperature would be to keep that volume the same and increase the pressure (i.e. a pressure cooker)... that's that one dealt with.
No worries! it's all good and harmless light entertainment!dickm":3bw8cg9o said:Oh heck................. why did I start this????????????
My fault - I should have said "water vapour can be hotter than the boiling water, depending on the apparatus" etc etcDon't know anything about it except that steam is hotter than boiling water, which maybe makes the difference.
Visible "steam" does not come from boiling water - it comes from invisible water vapour condensing to form water droplets. It starts life as invisible water vapour.Tony Spear":3lewzs3a said:......
Theoretically therefore, visible "steam" would be fractionally cooler than the boiling fluid from whence it came!
Thick stuff, eg, anything above about 4 or 6 mm bends better if it's steamed. Thin stuff, below about 4 mm can often be bent successfully if dunked in boiling water for a while. When steaming, common guidance is to allow one hour per 25 mm (1") of thickness in the steamer to get the centre of the wood hot enough to bend successfully. This is only a guide, and times vary quite a bit according to a range of factors, eg, the species, the MC of the wood, etc. Things like stringing or thick veneers at about 2- 3 mm thick and/or square can frequently be bent successfully with dry heat.Teckel":19ric14y said:All I wanted to know was "does it bend better with steam or actually putting it down in boiling water.."
Sgian Dubh":3f5hdp5j said:Teckel":3f5hdp5j said:I'm guessing you probably don't want to hear about plasticising wood by shoving it into a container that is able to withstand high pressure and subjecting it to gaseous ammonia... ha, ha... ha, ha, ha. Slainte.
Nah, I'm not going to get into it I'm afraid. Ammonia bending is mostly of interest to researchers-- wood scientists and the like, and only companies with a big budget to set up the process, with appropriate procedures and systems in place to cover H&S issues, are likely to investigate using ammonia to create bent wood forms. Slainte.marcros":2v6g9z3m said:Could be an interesting thing for a new post though?Sgian Dubh":2v6g9z3m said:I'm guessing you probably don't want to hear about plasticising wood by shoving it into a container that is able to withstand high pressure and subjecting it to gaseous ammonia... ha, ha... ha, ha, ha. Slainte.
