Just one other point. The trend reducers mentioned a couple of posts above are only 1.4mm thick. They would be great with a thin kerf blade using say 1.7mm plate and 2.2mm wide teeth. The washer wants to be just a touch thinner than the plate.
If you had an industrial saw blade made of substantially thicker plate, I'd prefer a thicker bush, closer to the thickness of the blades plate but never more than that.
