Myfordman
In Remembrance 25/12/24 -- AKA 9Fingers
40uF per horsepower to run and an additional 3 to 5 times that in parallel to start. 220k ohms 1 watt resistors in parallel with start and run capacitors for safety discharge.
Thanks bob that’s brilliant. Now why is this information not presented in such a concise and easy to understand way anywhere else on the interwebs? I suspect that those who want to be seen as internet gurus don’t really have the knowledge and those that have the knowledge are too busy using it to waste time with internet gurudom! This motor is 2hp but the lathe I’m interested in buying is 1hp. I might buy 2 x 40uf capacitors to experiment with on this one and if that works out ok, use one on the lathe. If I don’t mind the motor taking a few seconds to get to full speed do you think that will be ok?Myfordman":3kwzfbhs said:40uF per horsepower to run and an additional 3 to 5 times that in parallel to start. 220k ohms 1 watt resistors in parallel with start and run capacitors for safety discharge.
Eagle eyes there bob! There are actually two wires in each winding however the end of one of the white tabbed wires snapped off when I undid the star point. You might be able to see a bit of it sticking out from the end of the red tabbed connection.Myfordman":3kwzfbhs said:I'm concerned that your white tab appears only to have one wire and the red and blue have two each. I think all connections should have the same number of wires.
memzey":11ia8seb said:Thanks bob that’s brilliant. Now why is this information not presented in such a concise and easy to understand way anywhere else on the interwebs? I suspect that those who want to be seen as internet gurus don’t really have the knowledge and those that have the knowledge are too busy using it to waste time with internet gurudom! This motor is 2hp but the lathe I’m interested in buying is 1hp. I might buy 2 x 40uf capacitors to experiment with on this one and if that works out ok, use one on the lathe. If I don’t mind the motor taking a few seconds to get to full speed do you think that will be ok?Myfordman":11ia8seb said:40uF per horsepower to run and an additional 3 to 5 times that in parallel to start. 220k ohms 1 watt resistors in parallel with start and run capacitors for safety discharge.
Eagle eyes there bob! There are actually two wires in each winding however the end of one of the white tabbed wires snapped off when I undid the star point. You might be able to see a bit of it sticking out from the end of the red tabbed connection.Myfordman":11ia8seb said:I'm concerned that your white tab appears only to have one wire and the red and blue have two each. I think all connections should have the same number of wires.
When I measured the resistance for each winding (using the parameters as described by Mike) the reading for each was less than 1 on the scale of the meter but not exactly the same. They varied by about one or two scale notches between them. I assume this is ok?
