Dave65
Here's my 607's lever cap and blade, notice: Mattheson Glasgow, but cuts well.
Your teasing me with your genuine lever cap now Sammy
![😀 😀](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
Dave, when you get your lever cap, this old thread may help.
https://www.ukworkshop.co.uk/threads/another-cleanup-question-lever-caps.73625
With regard to my plane , its only very slightly concave so I'm going to wait until its back together and give it a try, with the new cap iron in, and see if it works ok. If it does work ok , then it will be left alone and used as normal.
They then had the task of finding a diplomatic way of telling the purchaser that they had just discovered that their 'straight edge' wasn't as straight as the plane sole!
I think that's what you'd call un-faultable logic......... I’m more inclined to leave it alone as long as it works ok....
I do remember being told that green Rizla‘s are exactly 1000th of an inch thick, the engineers used to use them by sticking them onto the piece of material they were working on and when the cutter came into contact with the Rizla and whisked it away, they could zero the machine.
The things you remember, strange isn’t it. Ian
That said, a concave sole is definitely a problem, so if your plane only cuts at the beginning & end of the board, it'll need attention, but wait 'til you get to that bridge before you jump off it!
Dave You have a very nice example of a 607 bedrock there and for an amazing price. I’ve got one myself which is very nice to use, but the sole is a little pitted although it doesn’t affect its use. I also paid quite a lot more for it on eBay a few years ago than yours. If you keep checking on eBay the missing parts will turn up there’s much more to choose from in the US. try to make sure you Get a lever cap with keyhole shaped hole not a kidney shape one as I don’t think they were introduced until the thirties and if you want authenticity it should just say bedrock. Looking at your pictures I think you have a type 5 or 6, most likely a 6 as they were made from 1912-1921. Another site to help identify it: Stanley Bed Rock Plane Types - Bob Kaune - Antique & Used Tools This site will also help you with the iron and chip breaker. Good luck hope something comes along soon. Martin
Great to see someone who has a drive to find real skills, and not only interested in
edited and flashy stuff, and sees value in real time video.
I will add that to take full length shavings the work needs to be flat beforehand.
Another thing you might notice is David is using the cap iron that is set very close to the cutting edge, as you can see shavings coming straight up out of the plane, compared to curlier shavings you might see wth other folks.
Using the cap iron combined with holding the work in the vice both vastly reduce the chance for the plane to nose dive off the end, creating a convex profile.
See David Charlesworth's planing a straight edge video's to understand this.
As you can see the plane will not cut into a hollow, it would need to be really really convex for a plane to be able to do so,
Material deflection is another thing to be aware of, if you have a thin panel with the bowed side down, it will sit on the corners, and not see saw about.
You can flip the board over and take out the errors to counter and eliminate deflection/springing back.
Only then have you got to the stage you might "eventually" notice a plane that needs further tuning...
But by then you have achieved your goal of a flat panel already.
Just in case you get the impression that the plane is needing work when it might be better to leave it.
All the best
Tom
Try the two links below to put a date to the blade. It does look like a later one with the rounded top corners.
.http://www.hansbrunnertools.com/Stanley%20by%20numbers/Dating%20Bench%20Planes.htm
http://www.supertool.com/StanleyBG/stan1.htm
Nigel.
