EdK
Hello all,
I need some stairs.
I'm rennovating an old granite cottage and the old stairs were like the matterhorn and knackered. Building inspector knows about all the work and the lack of stairs so ok on that front.
The details:
Total rise: 2522
Max total run : 3000 happier with 2400 but won't get the 41.9 degrees with that.
The total going is variable.
3000 (angle of 37.8 degs) = 13 risers at 194 / 12 going at 250
2904 (angle of 38.7 degs) = 13 risers at 194 / 12 going at 242
2772 (angle of 40 degs) = 13 risers at 194 / 12 going at 231
I've got a block wall running on one side for most of the way and this kicks back by 250mm to a brick wall.
The other long side is currently into the main downstairs room (will post plans/pics later when I find the camera).
The end upstairs has a 900mm landing (can move the stud back if need be - house is plasterless and only studwork up no wiring/no plumbing... ooo and getting chilly btw ). The downstairs ends against a hall wall (which can be moved back if need be) and at 3000mm total going would give me 600mm to the wall.
If I go with 3000mm TG then I am thinking of adding a landing 90 degrees at the bottom step so you don't run into a wall.
Couple of questions:
Do you normally plaster before adding a staircase?
What is a nice combination of rise/going?
The narrowest part is 800mm - is this too narrow?
(From what I have read there is no regs on width.)
I can move the joist over a bit I think to give a bit more...
Boxing in... The struct eng is suggesting that I box in the side to the main room to keep heat downstairs. This will give a closed stair. Anyone got one? Does it feel too boxed in?
I have plenty of light above from two C04 velux.
I have looked at Magnet and Jeldwen but they all seem to be 860mm wide and cheaper ones with MDF treads/risers.
I then thought that I have a router/SCMS/ a few other tools and plenty of time between now and January so thought I'd have a go. Never done much with wood but am careful and precise normally and keen to do alot more.
How much wood do staircases like this use up?
Planning on housed stringer on both sides and a handrail on the block wall side.
I was thinking that a nice wood would be good... what woods are suitable for staircases. Am thinking oak but have not used this before and am not sure if I would be better with pine and a carpet... In my mind the stairs are a lovely natural wood though !
Currently reading Scott Scuttner's book Basic Stairbuilding...
Any advice to help me make one or point me away from this idea and buy one greatly appreciated.
(Local joiners are not interested...and they charge £2500...not until Feb...)
Ed
I need some stairs.
The details:
Total rise: 2522
Ed
