gasman
Sorry about slow progress - more jobs from my wife getting in the way of my favourite hobby!
I carefully drilled the other holes in the sides of the plane going through the infill and this time made a much better job of enlarging the hole in the infill to accommodate the brass tube.
Instead of just using increasing size drill bits like I did last time, I used my tapered reamer to enlarge the holes in either side of the infill a fraction larger than the final size then used drills / hand reamers to enlarge these holes gradually. That way the enlargement remained concentric and I ended up with the rods fitting exactly.
So all that is left is to rivet the holes - without touching the sides at all. Thanks rxh for your ideas on using the mill then a scraper - seems like a really smart solution I will try!
