New to spraying--hence questions.
I want to spray clear gloss lacquer onto a painted wooden surface that will be used--in this case a banjo wooden back. (Known as a 'Resonator'.)
a) How many coats of lacquer before it is lightly sanded before applying the next coat?
b) Time between coats?
c) Use wet & dry paper ? Grit? Use the paper wet or dry?
d) Any other advice welcome.
Look forward to your answers.
Many thanks.
Many thanks.
