My son a architect comes up with unusual designs for me to produce, the current is a book case which is best described as a number of different sized boxes some shallow others deep all assembled into a unit to form the case .I am thinking MDF as there is a lot of board area, mitre lock construction and when i mentioned spray painting it triggered ideas for different colours for some of the boxes .
So the problem is spraying MDF from search results HVLP seems to be the way to go and maybe eggshell paint then we get into different makes, thinning and needle size, paint type, primers etc.Can any one put me right in a not over expensive way that will work with the minimum of adjustment ,i have not sprayed before but like the idea of spray finishing hard wood projects in the future after this coloured work.
