blackrodd
Peter, as you say, the saw doctor won't be very busy now with circular saws, now that TCT blades are so common place and cheap.
Laser welding has helped as the old method of brazing teeth and then grinding to the finished item was rather labourious, and very costly.
The need to re tension the old steel circular saw blades is a thing of the past, but I would think that the bigger bandsaw blades will need looking after, keeping the crown's shape, which, after all keeps the blade tracking and running even. And the steel's tension, should the saw blade over heat by material jamming the in the guide.
If I may say so, that's a Really good and practical article you have written there on using the spindle moulder
I have often thought that EVERY spindle moulder sold should come with tuition just like that, getting the best from you're equipment and the need for safety, as these tools can really bite.
Here's Some scary stuff, years ago, to maximise feed speed and production, on some planers and many six cutter moulding machines, the cutters were "jointed" this meant that a carborundum stick was moved by hand along a slide to equalise the setting and then honed.
I believe some forage harvesters are sharpened in the same manner but the user pulls and pushes a rod, attached to the grinding stick, keeping hands well away.
Regards Rodders
Regards Rodders
