If I was to get some 4 mm from Australia, do you have a recommended source? ....
Unfortunately, no, Richard. Local merchants just don't carry 4mm as far as I can find. I found my bit on the interweb but have not seen any more since - I must've got the last bit! All I can find now are large, full sheets, which are well out of my budget range.
As I complained, over here, most of the brass offered is in Imperial sizes, even that advertised in metric units often turns out to be Imperial. 5/32" would be close enough to 4mm for practical purposes, but no-one here carries that size.
Keep searching, you may get lucky - they obviously make plenty of 4mm in that large country up there to the north of us, you can find any amount of 4mm by the truckload on Ali Baba.
There are various suggestions you'll see for protecting the surrounding metal from erant hammer blows. One way is to use a punch, as you mentioned. That can be good, but you need an off-sider to hold the job so you can use both hands. I find that extremely awkward, I need to be able to feel the plane on the anvil to know I'm striking with it solidly supported under the point of impact. Oher suggestions are to cut out bits of jam tin & fit them over the pins (really hard to do sufficiently neatly to do any good). Others suggest duct tape or something similar. That's probably the easiest to apply, but does the least good, in my experience.
I've hammered enough dovetails now that I don't worry about protection, my mis-hits are usually just glancing & minor. Having said that, I did make a more serious ding on my last plane - drifted into autopilot & lost focus, but fortunately, the dent filed out without too much metal needing to be removed. Do your peening in bursts, and if your arm starts to tire, which is when inaccuracy sets in, take a break - doesn't matter if you finish peening in an hour or a day or a week. I always take a good break when I think I've finished, & go off & have a cuppa or cut the grass, then go back calm & fresh & go over the whole thing again, checking each pin & tail carefully & giving them all an extra whack or 10 for good measure. Since I started doing that the pinholes have diminished to near zero, but the odd one still sneaks through. As I've said before, I have a profound respect for the blokes at Spiers &co who peened all day every day, consistently getting them so damned good!
I strongly recommend making at least one small plane before launching on a biggie like a panel plane. You'll pick up an awful lot on the first few jobs, and your skill level goes up exponentially. And best of all, if you do make a mess you haven't blown a hundred buck's worth of material....
Cheers,
