Shultzy
I think the square corners are the least of your worries. To cut an area of 600mm x 400mm you will need an accurate sledge to hold the router. This will allow you to move the router up and down and side to side. This can be done with a 1/2" straight in two passes of 4mm and 3mm. To get an accurate base you need a surface trim cutter which will give you a flat bottom. I've chose the two cutter route as the 1/2" cutters are about £12, and will do most of the work, and the 50mm surface cutter is about £45.
My kitchen worktops are 10mm x 600mm x 600mm ceramic tiles and they are very, very heavy. How are you fixing these tiles to the chipboard? I would have had picture frames, professionally sprayed with white Lacquer.
