Spalted Beech hollow form plus other work
I will try to make the pictures a bit bigger to show more detail later
and as I say if you are interested in the process from start to finish I will post these too.
take care
Mark
A step by step photo shoot would be fabulous. I don't know how many people I speak for but as a newcomer, being able to see how things look at each stage gives me a good reference that at least I am heading in the right direction. Albeit on a different road, but the right direction nontheless! Fabulous work, on here and your website. No galleries near me to see them in the flesh though :(
Jez
Hi Mark,
I agree, step by step shots are an invaluable aid for us beginners, and it would be much appreciated if you were to go to the trouble of posting.
Will you be after George's crown as the WIP king? :wink:
Malc :D
These are the first two parts. The closed form with a fine crack and the ivy.
The form with a close up of the crack
The next thing I did was to turn the profile of the form and the inside true with a 1/2" bowl gouge. I use this tool for nearly all of my work.
My gouge has a finger nail profile with the wings ground back. I use a Robert Sorby Universal grinding jig
The out side was than sanded using hook and loop abrasive on a standard 2" arbor.
I then sanded the inside with a cut down 2" hook and loop pad/arbor which is fixed to into a drill extension. This one is 300mm, made by draper and cost around £7. It was used in a standard drill as below
This is a picture of it being used on the lathe to sand the inside. By resting it on the tool rest and lightly covering the rotating shaft with my fingers I can control the sanding. I used a 120 grit at this stage then down through the grits.
Once done I drew my desired design on the form to cover the crack.
For this I use white board marker as if you use permanent it can soak into the wood and stain it. It can be a real pain to get rid of if you do not like the design. A white board marker can easily be sanded out so you can start again.
Once I am happy with the design the nest stage was to turn down the chuck spigot to as small a diameter.
This was done by blending the base curve in around to keep a flowing line by using a 1/4" spindle gouge. But you could use a 1/4 parting tool or even the 1/2" gouge. But my going to a smaller gouge you can get better access. This was then simply cut off with a fine saw.
The remains of the spigot that the saw left behind I then removed with a proxon carver. But a sharp craft knife, chisel can be just as effective. Watch you finger as they are very sharp.
The base was then blended in by hand using 120 grit. This being beech it is quite soft so blends nicely. Then I blend down through the grits to around 320. there is going to be a lot more work done to the piece so no need to go too fine with the finish at this stage.
You can still see the fine lines of the drawn area to be cut out.
This was simply cut out using a Bosch jig saw. By keeping the cutting blade at 90 deg as you move around the form you can cut it out quickly without hitting into the base.
In this picture you can see I have cut it out. You will also notice that the wall thickness is not even. IE it gets thicker towards the base. This is done deliberately. If you turn the wall thickness thin and even when you come to carve it out there will not be much material to blend the edges out.
This will result in a flat form. By leaving the wall thickness thicker at the base you have more carving scope and the light will throw a shadow on the finish piece giving it much more depth and appeal
The edges were then blended back by 1/2- 3/4" using a 120grit abrasive on a hook and loop arbor in a Foredom rotary spindle/carver. You can see now the reason for leaving it thicker at the base. It gives the carved area much more depth and interest before I had one of these I would do it by using chisels, files and abrasive wrapped around file etc.
This was then blended back into the rest of the form by hand and finally the whole piece was finished down to 600 grit.
Next I played around with different ideas using the Ivy for a base.
I liked the one of the form being on it's side with the cut out facing at an angle.
I decided it would need a base so using a left over of a ash plank I placed the ivy and form on top and drew a design that I thought would work. Again mulling over this before cutting.
Once I was happy I cut out the base with a jig saw.
The edges were then roughly blended back with an arbortech carver in an angle grinder. using full face protection as the splinters can really fly. You can't see it in the picture but the base was held down by a clamp to keep my hands out of the way. Then moved as and when
the edges were then refined using my rotary carver with a burr, then a hook and loop arbor with 120 grit on the lathe. Make sure you have suitable air extraction and face protection.
Once the base was sanded down to 600 grit I placed the Ivy with the form on top to see how it was going. I left the Ivy intact at this time so that I had more design options later if I wanted to change it.
the base was then ebonised/stained black with chestnut spirit stain. giving it several good coatings to allow it to soak in.
It was brushed on. make sure you open the doors and have ventilation.
The I played around again to see other design opportunities
Three eggs were then turned on the lathe ( sorry didn't take any pics of this)
these were made of left over anjan.
Originally I scorch the ivy and placed the anjan eggs into the form but there was too much going on.
So I cut back the ivy to natural colour using abrasive and ebonised the eggs so that they would match the base colour.
The base was then buffed with a black wax made by Liberon and buffed by hand.
The ivy was cut to a length I was happy with.
The form and ivy were coated in renaissance wax with four coats and again buffed by hand.
I then set the ivy form and eggs together on the base to make sure I was happy.
The ivy was then cut and fixed onto the base using fine metal nails with the heads removed and glued into place.
The form and eggs were left free so that people can move it around to suit the preference.
With this being the end result.
It is a bit of a rush this morning as I need to get out and do things.
I will post more pictures of the finish piece later from different angles, in larger format.
If there is anything that is not clear or you want to know. Just ask.
take care and I hope it has been of interest.
Mark
Thanks for the WIP pictures Mark, they say a picture is worth a thousand words but you precis of the process accompanying them strikes a good balance.
Very intriguing the way you have done this Mark, gets the old mind juices flowing. Believe me I need some just now. Very impressed the way you saved that form.
Mark,
Thanks so much for sharing your work and processes, I'm just blown away.
Your pieces have a great tactile appeal for me I just want to hold them and feel the curves :shock: and look at the details.
Please keep posting
Regards,
Mike C
CHJ
Thank you for your comment. I am glad it is useful.
Jenx
Thank you
The next one I intend to do is to show how I make one of my lidded pots/hollow forms from green/unseasoned wood, through to finishing and making the lid. But it may be a while as I need to get lots of roughing done due to running a bit into the low side.
TEP
Thank you. I never throw any disasters away unless they are totally gone. Thankfully now I do not get too many only the odd one every now and then.
Glad you found it interesting.
mikec
Thank you. Don't worry I know what you mean. Work I agree should be touched and that is one of the privileges of working with wood as it is so warm to touch, as opposed to other media. Which in my view is very beautiful but not as tactile due to being cold.
Take care and thanks again all
Mark
Paper weights
These are quite a nice project to make if any one is interested and they are good sellers as they have a use, are small enough for people to pick up and take away with them at a show/fair.
They are around 100mm dia but you can make them any size. they have a anjan insert in the base so that when they are turned over they have extra interest. Also this covers a screw chuck hole.
They are a brilliant way to use up off cuts that are too small for bowls etc.
They are also nice just to sit on the side board as a tactile ornament.
Finished in Renaissance wax and buffed.
Bodrighy":3fj59ky3 said:
Are these heavy enough for paperweights Mark or do you put something in them
Just a thought for 'weight' Pete, if you needed a bit of 'mass' ....
Cheap tin of Airgun Pellets about £4 for 500 off fleabay, and a blowlamp.
( and something to use as a crucible ... one of the missus's old pots does me, when I've done something along similar lines with some lead. )
nice and heavy :wink:
Hi Pete
yes they are quite weighty as they are around 100mm x 60mm. I also make them in Yew, Oak etc.
You can certainly put lead shot in them if you like.
Some people I know also put a coin in the top that refers to the date of birth of the person they are making them for, so you could put the lead below this.
I have to say that most people buy them just as they are so tactile and just put them on a shelf.
Take care
Mark
Jenx":fzrwwbzy said:
Jenx
Thanks for the idea. A quick question.
How do you pick out a bit of text that has been written and "quote it" I have been trying but can't seem to find an easy way.
Mark
Click on quote as you've been doing then simply delete the words you don't want. Don't think there is an easier way.
Now someone will come on and prove me wrong :roll:
Thats the way I do it too ....
Click the QUOTE button in the post yuou want to quote from,
then.. as long as you keep the {quote} and the {/quote} at either end of the relevant text, you can 'edit' away to your hearts content ! .. but use the [] square brackets and not the curly ones like {} these :wink:
If you want to quote from 'multiple' posts ... I use the 'cut and paste' technique and put them into my final post, containing all the different quotes.. its a bit of a 'fanyachh' about, but it works. :wink:
Unless theres an easier way ?
8)
ah I see.
technology gets me every time. Give me a spinning piece of wood and a piece of metal to poke at it any day.
Thanks for that
M
That photo walk through is fantastic Mark. Thanks for sharing. I spent the afternoon making a grinding jig, so it is good to see what standard I could be up to in 9 years if I keep practicing! :D
