Source of thin wide boards - Walnut
Jason Wheeler
UKW Supporter
16 Aug 2023
I am going to be making a couple of cabinets and as they are going to be fiddly and use a lot of wood.
I wondered if anybody has a good UK source for thin (10mm or under) cut walnut (doesn’t have to be walnut, could be something else).
I can resaw larger pieces and have a thicknesser and drum sander but I would prefer to spend time on the making rather than the wood prep - trouble is the few places I have found online are way more expensive than I want to spend!
Hi Jason, could you buy the thickest construction veneer and glue it back together in a vacuum press? Not sure how it would work out pricewise.
I am going to be making a couple of cabinets and as they are going to be fiddly and use a lot golf wood, I wondered if anybody has a good UK source for thin (10mm or under) cut walnut (doesn’t have to be walnut, could be something else) - I can resaw larger pieces and have a thicknesser and drum sander but I would prefer to spend time on the making rather than the wood prep - trouble is the few places I have found online are way more expensive than I want to spend!
I assume that you want ABW - in which case, it is (relatively) expensive. I buy from Whitmore's in Claybrook Magna, Leicestershire. but you don't indicate (in your profile) where you are located so I have no idea whether that is a viable place for you to visit. You could no doubt 'buy blind' - ie. let them select a board (or two) for you. They do have vast stocks.
The last I bought was a 3m length of 1¼" x ~4" which cost me £38 collected, which may give you an idea.
That’s a really interesting thought, thank you - I have vacuum pressed veneer before although admittedly only small pieces and never thought about making a veneer ply - not sure how it would look on exposed joints though..
Am in Northants so not too far - that’s a better board price than I have been seeing, thank you, although the it’s a lot of resawing if I go that route
They are well worth a visit but you have to phone and book a [slot] which is 2 hours.
When I bought that 3m length I was there an hour and a ¼ and they moved about 8 very large stacks of timber to dig out the board I eventually selected. You do have to take whole boards though, ie. you can't say "I want 1.5m off that one" but they do have varying lengths, thicknesses.and widths.
It's a huge site and of course they have a large variety of species as well.
