Jacob":3vw0g1pu said:
It's no either way. Sunrise is latest at the solstice (by definition) and stays close to 8.06 am (in London) from Dec 26 to Jan 4, though there may be small deviations in seconds which wouldn't be noticeable staring up into the wintry dawn of a December morning north of Aberdeen, unless you were working away with sextant and chronometer.
Not really correct. The definition of the solstice is that it occurs on the 2 days in the year when the sun is furthest from the celestial equator - i.e. furthest north for the summer solstice (21st June) and furthest south when it's the winter solstice (21st Dec). In the northern hemisphere, these will be the dates of maximum(summer) daylight or minimum (winter) daylight hours. In the northern hemisphere these will be the days which have the longest and shortest time between sunrise and sunset, and would have been recognised by our distant ancestors as the days when the midday sun was at it's annual highest or lowest above the horizon..
However, as previously mentioned, although the day with the least daylight in the northern hemisphere occurs on 21st Dec (hence it defining the winter solstice), this is not the date of the latest sunrise or the earliest sunset. In the time the earth rotates through 360 degrees on its axis it also travels around the sun in its orbit. Given that there are 365 days in a year and 360 degrees in a circle, the earth has to rotate approximately 361 degrees before the same face is precisely orientated toward the sun. If the earth's speed around the sun was constant there would be no problem, but it isn't. Because the earth's orbit is slightly elliptical, when the earth is at it's closest to the sun which occurs in December (Perihelion) it travels faster in its orbit than when it is at it's furthest (Aphelion). When it travels fastest (and therefore further along its orbit in the time it takes to complete one 360 degree rotation), the earth has to rotate slightly more to present the same face to the sun in December than it does in June.
This is why the earliest sunset occurs around 14th Dec and the latest sunrise occurs around 1st January (it is not precisely the same each year - don't mention the celestial mechanics of leap years or the "precession of the equinoxes"!). However, the shortest hours of daylight (i.e. the shortest time between sunrise and sunset) will still, by definition, be on the winter solstice on 21st Dec. If you think that this all sounds very pedantic, and an exercise in semantics, you would be right. but it is an interesting point of discussion and it's nice to understand the workings of the world around you! :lol:
