whatknot
No I don't mean putting it in your pipe ;-)
I try and use recycled wood wherever I can, scroll saw work & band saw boxes mostly
I had some pallet bearers, and the last one had a split right up the middle of one side
So I thought I would try superglue first but its a bit watery so doesn't fill the gap (which was a lot wider in other parts of the same wood)
After using the superglue I reached to get some epoxy glue and noticed smoke coming from the crack
What would make it smoke?
I then mixed up some epoxy and filled the crack, after setting it sanded down fine and it was usable
I made some small beach hut boxes with it
