It also seems that any second hand options are like rocking horse poo. The search continues, unless anyone has any ideas? Where is the best place for second hand gear? Any shops in the South West which can be recommended?
Duncan A":c3nre93p said:"If google translation (KW and Ws to HP) is right the Record is 0.2HP and the Axminster is 0.5HP."
Not sure where you got your figures from but the RP DML 250 and the Axi AC240WL are both 375W i.e. 0.5hp.
Duncan
SVB":yp5l0d1a said:you mention you are new to turning..... You comment you turn on slow speed and sand fast. Sanding fast will both dull the abrasive quickly, run the risk of burning your fingers.
Simon
8squared":sr6amlul said:I have burnt my fingers on a few occasions... just thought i was applying too much pressure... and yes I do go through a fair bit of sand paper.
8squared":8yagoo95 said:Here is a photo of it in my workshed........ a little higher than i thought it wold be so to give it a test (although i had already seen it working on collection), i laid down some wooden planks to create a platform for standing on.
What is the ideal height to have a work piece?
