Small Routers
I had a small B&D plunge router which I bought second hand many years ago. Plastic construction so when that gave way I simply pop rivetted ally bits on. Anyway,recently it went bang so took it apart to find that one sealed bearing it had virtually seized up causing one segment to go out - oh,how I miss the growlers from work days! Just did a test meter check. Left bearing in penetrating oil for a couple of days - no change so bought another bearing, put it back together and it worked - for two minutes. I'd gotten (sorry,I spend a lot of time in Texas) so missed it, Bought an identical model for under £20 on EBay which was in it's box and like new! Sorry to go on but the of the morel of this story is to keep your sealed bearing lubricated. Oh, I had forgotten that I had left the old bearing in the penetrating oil for about a week and found it was as good as new - so there's another moral!
I have the Makita 700 corded, the full kit including angle and plunge bases etc. Had it for years and it's my go to for hand routing and has been faultless so far. I still like my ancient little Elu 96E which though suspect that's more sentimental than practical and these days the two large routers are rarely used hand held with one set up permanently in the router table.
I use the cordless Makita DRT50 (Makita product page) Whilst I've very little experience in either woodworking or other manufacturers, this has been faultless.
A few things I like...
  • power and batter life are fine
  • I can vary the speed,
  • base plate is big enough without being cumbersome on small pieces
  • base plate is perfectly round - great if using in a jig
  • dust extraction whilst a faff is effective
  • weight is nice balance between heavy enough to feel planted to the surface but not too heavy that I can use it in odd angle (which you probably shouldn't, so don't try that at home kids)
That said, I *think* my advice first would be to stick to whatever battery system you have - Makita, Bosch, DeWalt etc.
As evidence I humbly submit...
The inside of the bowl really was using a router, I wanted to see if I could :D
    1.6 MB
    2.6 MB
I have the dewalt and also have the additional plunge base for it which turns it into a normal router. I have not had any problems at all with it. I narrowed it down to the Makita or dewalt but went with rhe dewalt. I think because I found an offer that included the plunge base. Fantastic bit of kit but I would think the Makita is as good. I like the slow start up and led lights which really make a differance. And I have both the 1/4" and 8mm collets which also add to the versatility. Its also very stable in use when using it as a trim router. Very well balanced and easy to control.
Well I took the plunge and brought the corded 110 Dewalt D26204K router. It is slightly larger than my Bosch GKF600 but has variable speed and takes the 8mm collets. It is also much better when it comes to fitting the bases than the Bosch and adjustment with the circular ring is good, the Bosch was always somewhat fiddly. When you compare it to the Dewalt 625 which has been my go to router for many task it is much lighter and smaller, it has dawned on me that another reason for getting the smaller router with the 8mm collets is actually that for many task 8mm cutters are fine and getting older you don't want to be using a big heavy router when you really don't need to. The down side is that I now need to buy some 8mm shank cutters to do some edge molding but again for those bigger jobs the router table is still essential until I find the space and have a sort out to make space for potentially a spindle.
One other aspect is that I could use the peanut system where the cutters are only available in 1/2 & 8 mm but that is still very much undecided because like the Lamello P2 it introduces plastic into the joint, I seem to have the view that to join wood then wooden dowels, M&T's or anything wood feels better.
