Small Engine Project
Nigel Taylor
18 Oct 2020
UK
Is it just me or do you get stuck at a particular point on a project?
I've got stuck twice on this small engine and as a result it has sat on a shelf waiting for me to get inspiration, so I thought I would share the build to date:
Nice will it have a practical use boat / plane?
Where is the air intake?
On my old engines it used to be unfront just behind the prop.
Does it run on petrol with that spark plug.
Used to have PAW diesels, OS glow plug engines and a fox 35. Mainly flying c/l !!!!!
Cheers James
Nice work, Do you intend to run it? It's obviously air cooled, Is it a glo motor?
Gerry
Hi Gerry, Intention was spark ignition. Needs top end work completing then I can run it. Best regards, Nigel
Cheers James
Hi James, the air inlet port is in the head.
I need to make the carburetor and it will sit to one side of the head.
Intention is to run on petrol and spark ignition.
Plan was to use it in a tether car - just an idea in my head at the moment though.
Thanks, Nigel
Stuck?! I have 3 small very basic engines sitting on the shelf, two of which will never run due to my inadequacy as a machinist, while the third (Elmer's Grasshopper) I've lost patience with. Your engine is looking good, w-a-y beyond my capabilities, and you seem to be almost there. I'm sure we'd all like to see it running. :)
Re tethering my dad - mid 80's wrote this
Wow, the last time I saw that activity when I was about twelve. There was a model show at Romford YMCA which had tethered cars in the car park powered by American Dooling and McCoy glow racing engines. The local model shop owner was keen on them.
Cheers James
There are some great videos of them breaking 200mph, quite an interesting hobby
I've spent a long time learning the skills and building stuff that doesn't work - the stuff that doesn't work is just not shown ;)
I've tried to shift my woodworking hobby towards model engineering and it hasn't gone too well. I'm in my 70's and although I have no respiratory problems dust is a concern. Years ago there might have been evening classes for budding model engineers, but not today. I've been lucky to have a friend who is a superb engineer and model maker, and he has been generous in his knowledge and 'how to'. Without his help (and YouTube) I'd be lost.
I really like the combination of wood and metal work. I find it very relaxing and helps me clear my head. Dust is one of my concerns, I do use a dust extractor on machines and a general workshop dust filter that cleans the volume of air every couple of minutes. This is in addition to a mask.
Also, I've been trying to build pages to help with engineering, some of these are based on the ways I've learnt to do things. I'm not trained in engineering and this has been noted by some with the comments I've had.
