pgrbff
Is there any reason why you couldn't use a 180mm grooving blade, say 6mm wide, in a large table saw like a Startrite that would normally take 10" or even 12" blades?
That is what I would normally do but I would still have to buy a flat ground tooth. For box joints etc a wider blade would be far quicker.No, but I'd take note of the saw rpm and compare that to the recommended speed range for the blade that you choose. Small dia blade in a 12" saw will have a lower surface speed / minute at the cutting edges.
Bigger industrial saw blades often have a kerf in the 4.x mm range. If you are only making a few cuts you could just take 2 passes adjusting the fence to get your 6mm groove.
Because I would have to buy a flat ground blade and a 6mm blade will be far quicker. I would prefer a box joint blade but these are not readily available in the UK.I seem to remember that DeWALT used to have a dado blade for their radial arm saw that was much smaller in diameter than the saw blade. Thinking back it was probably around 8" - I'm sure others will be able supply the exact dimensions. So, I can't see this being a problem. In fact it may well be an advantage slowing down the peripheral speed, if the cut is wider. Though it does beg the question - why not make multiple passes with an ordinary blade?
