Sussex cabinet maker
hello everyone, thank you for all your responses. all extremely helpful and its good to hear its not just be being an idiot!
So after some investigation i've found that the small hole in the bottom of the casting by the pulleys does lock the shaft, but very badly. I jammed a bradawl in and although it did help tighten the locking nut down, its totally bent my bradawl and is not going to be a long term solution.
The overall machine is perfect for what i'm currently needing it for other than it being a nightmare to set up, so investing some money into a modification on the top seems to be the only option. I like the idea of a grub screw thats welded into place, I just need to find an engineer that could carry out the work. One other option i've thought of is getting the thread on the shaft cut in to a lower point, so the locking nut could sit lower, and flat spots could be added for a second spanner.
Lastly i've heard rumour that the shafts can be changed out on these machines quite easily, which again has been mentions in this thread, I will investigate this as it's currently 1 1/4 and it would be handy to be able to change over to 30mm but I guess that down if mine can be changed, and if I can source a 30mm one.
thanks again for all the help!!
