Sliding mitre saws
Pep
New member
23 Dec 2009
I am thinkimg about buying a sliding mitre saw and I thought the ryobi one looks quite good, has anyone got experience with these.
Hi pep.
I have the Ryobi SCMS and I certainly wouldnt recommend it to anyone that wants accuracy out of the box.
I would however recommend the the Axminster SCMS with the Induction motor goes for about £270ish i believe, but well worth it.
Hope this helps
Andy
I have seen a few saws with a 90mm depth of cut and about 300mm cross cut.
What I really want though is the mitre angles to be correct.
I have looked at quite a few and when you locate them in the 45 deg position they can be moved 1 or 2 deg's in either direction.
Not good if you are making cabinet doors etc.
Any idea's chaps would be much appreciated
David
Really? I'd guess then that you've been looking at some of the cheaper saws in B&Q or somewhere similar? I've used saws by DeWalt, Makita and Bosch in the past but have never noticed this... A lot of saws now have any 'over-ride' feature of some sort which allows you to make fine-adjustment to the preset angles that locate in the detents underneath.
I'm trying to sell a 12in. Bosch saw at the minute. I wouldn't rate it highly for accurate, wide cross-cuts (I assume it's the same with many saws?) but it's got great capacities and has handled everything I've thrown at it. :)
Have you used the search facility? Search the buying forum for Mitre and you'll find a few threads. One that I started is here
I didn't need too much of a cut, and I wanted a small machine to fit on a workbench, so I went for the DW777. But if I wanted a larger cut and didn't have to worry about the space, I'd probably have gone for the Makita LS1013 which is £348. The reviews on here (search this forum for LS1013) and amazon (go and have a read) are glowing. Bevels both ways, and is accurate.
Popular Woodworking said: "We can't recommend this tool enough. It's won every award this magazine gives out, and has earned a permanent place in our shop because it's tough and accurate"
If you need larger, there's the LS1014.
Triggaaar, where did you find the LS1013 going for £348 please?
If I can sell my Bosch, that is the saw I'm looking to go for - it's probably the one I should have bought two-years ago! :roll: Also, Ben Plewes (The Woodworker and Good Woodworking magazines) rates his LS1014 very highly.
I expect it would've been anglia tool centre - price is now £359 (would've been £351 before vat increase, and i guess they've increased the price a couple of pounds). I got my DW777 from them and had good service.
After a lot off looking around and trying out a few saws i went for the bosch gcm 12sd excellent cutting capacities and very smooth and it comes with a 3 year warranty have to say very accurate cutting mitres have done a good few and all were nice and accurate.
I don't know how helpful this is but I've got the cheap Bosch mitre saw (GCM800S) which is perfectly adequate for what I use it for and is small and light enough to be stored on a shelf underneath my workbench when I don't need it. I haven't had to adjust the angles yet because it's only 2 thou out of square at full capacity (270mm) so will do fine for me! Anything wider then I use my plunge saw anyway so the saving I made from not buying a larger mitre saw paid the difference between the circular saw I was going to buy and the plunge saw if you get me... but this is my way of justifying it!!
Mark
