DrPhill
Cyber Heretic
- Joined
- 15 Feb 2012
- Messages
- 1,154
- Reaction score
- 314
Finally getting round to the skirting now.
Plenty of good advice memorised from thie forum: Start opposite the door (which is the longest bit as well). Work my way round. Use coping for the internal corners (pointing away from the centre), and miter the external ones (pointing into the centre).
But: Is there a 'best' (read easiest) way to do the bay? It is a 'splayed bay' - the sides are not parallel. Should I do the outside-most bit first (furthest from the centre of the room)? Or should I do this last? Should I attempt to cope the external corners which are probably 135 degrees, or should I use the miter saw 0n 67.5 degrees? Thankfully the profile is simple, so I may be able to cope (groan, sorry).
I would appreciate any advice before I create kindling..........
Phill
Phill
