Hi,
I wonder if someone could point me in the right direction, as this skirting is starting to be expensive with the waste ....err, mistakes!
I was on a while back on how to put some skirting around a few pillars, however I'm just getting round to it now and can't seem to grasp things, and I'm still only on the first mitre, which is an external.
The wall is neither plumb and the floor is slightly out so when I'm butting the external mitre it does look O.K. however there's a 5mm gap on the floor.
There's also a gap on the top edge, which isn't too bad and could sort with some caulking.
Does this mean I would have to scribe the bottom to the floor, which I'm hoping not to, or could I fiddle with the angle of the mitre cuts?
I have all the tools, bevel, trend mitre gauge (not the type that halves the angles though) and a decent mitre saw and just lacking the know how and little tricks I'm sure you guys know.
Any advice or tips please?
Thanks lads
Phil
Thanks lads
Phil
