Alf":cph4e515 said:
I apologize for such a long series of posts. Your picture does show the difference quite well.
But, is the blade projecting out of the sole the same--i.e., is it the same depth from one side of the blade to the other?
Even with just enough pressure from the lever cap to just stop it dropping off, I had a noticable difference in projection, and not enough leeway to compensate via lateral adjustment. Believe me, I tried...
Alf":cph4e515 said:
MikeW":cph4e515 said:
...I slide the blade so that the right edge is against the removable fence...
Er....? :? Explain that again, slowly. Don't get it - sorry.
The lower part of the blade which is wider than the upper portion is what I push against the removable side. It will slide over against it, but it is easy to move the back, thinner portion of the blade to far causing the leading edge of the skew to pivot away.
Alternately, you can remove the side and, with that side of the plane flat against your bench, wiggle the blade so that wider portion of the blade is also flat against the bench.
Also, and I imagine you've done this, without looking at the mouth/blade gap, go for just an even projection. Use a small double square set so you can check each side for evenness. You probably should make it way more projected than you would ever use just to make it easy to adjust for an even projection.
Then look at the gap between the blade and front of the mouth. If there is a difference, it can be caused by the blade not being correctly ground. But only if it is significant (whatever that means) does it indicate there's a problem.
I'm sure you've already done these things and I'm sorry that you are having this problem with the plane.
You really ought to contact LN if you cannot get it adjusted to your satisfaction. It could well mean there is something wrong with the angle the bed is ground from the leading side to the trailing side. Which is weird geometry in itself. (Try making a skewed plane...)
The one degree you mention in a different post truly affects the whole blade/mouth issue as well. If you think the 140 is hard to get the skew angle correct, try the 98/99s--even Leonard Lee thinks they are about the hardest...
Sorry I cannot be of more help than that right now. My brain hurts
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
