Chrispy
First I have to apologize, if I only new then what i was in for I would have made a WIP and recorded the progress.
Six weeks ago my new toy an old Rye CNC router was delivered, now I was prepared for a week or two to wire it in connect up some compressed air and sort out the software but over six weeks and it still aint working
Here's a few problems so far:-
A week before it was delivered I get notice to quit the workshop (next year)
While I waiting for the sparks to wire it in I have a little poke about and realize the air lubricator has been fitted backwards! and needed a good clean out so took it off cleaned it and then realized that it wouldn't go back together, it had also been fitted with the wrong sized O-rings, so the shopping list starts, order up a service kit and fit.
This is where I had planned on getting a engineer to take a look over and show me how to use the thing, well he came and looked and showed me how to grease and oil things and change the filters and vanes on the vacuum pump etc.
Then I mentioned that it looks like it had taken a bit of a wack (hammer) as one of the cast iron bearing mounts had a corner missing, :shock: so investigated and found the Y axis ball screw was worn and a strange clonking noise was found when rotating the said screw so thought this needs investigating so took things apart to find that the servo motor on the Y axis had started to de-laminate, ie three of the twelve magnets inside had come loose and were now sticking them selves to the rotor, this is where the engineer has had enough and goes home.
Do you want to here the next episode? :?:
