Silicon Carbide Abrasive Paper
niall Y
1 Nov 2018
CARDIGAN
I am in receipt of an order I placed a few days ago for some Silicon Carbide paper. I notice that what has been sent is Kingspor which I have been always led to believe is Aluminium Oxide.
Not a major problem, but I always prefer Silicon Carbide wet-and-dry for working metal and the Aluminium oxide I tend to use more for finishes.
Mind you Aluminium Oxide, seems to be getting in on the act elsewhere. as most of the Emery cloth products are now also made of this. Whatever happened to emery cloth actually being made of emery?
I wouldn't be surprised to find kingspor make SiC as well as Aluminium Oxide. Worth checking.
If you have been sent the wrong stuff, just ask the seller to send what you ordered.
Their mistake, they have to fix it, including return postage cost if they want the original back.
What are the colours ?
I don't think i've ever seen silicon carbide that wasn't black.
Alox is usually lighter.
Silicon Carbide I think of as fine, sharp and blunts quickly.
Alox more durable but not as sharp.
Different abrasives for different tasks.
Hi, @Sideways, thanks for the reply. I can be a bit of a minefield finding out what any particular wet-and -dry paper is made from. I have some code numbers on the back of the ordered sheets that I can check through, though nothing as helpful as the type of grit used. :unsure:
Klingspor's UK site has their wet and dry listed as SiC ( Silicon Carbide ), though many of the suppliers on Ebay, ( where I purchased mine from ) have it listed as Aluminium Oxide. I suppose it all boils down to the codes on the back, which I will check out tomorrow.
