Hello,
I have found that side sharpening gaga and this newest incarnation of a jig bullshit. Some woodworkers have too much energy to waste on endless, pointless and fruitless discussions... (and money to burn on things they should never buy)
Manual training and abilities differ from people to people. For example, I have difficulty in grinding and honing a straight edge on narrow blades freehand, so I used a jig to grind these, but I have not found any jig which is really suitable to hone narrow blades, under 6-8 mm or so. So I sharpen these narrow (4 mm and below) blades of mine with slips and stone files, moving the stone instead of the blade. And for producing a heavy chamber on a blade (e.g. a scrub plane iron) I use the same method...
By the way, a mildly chambered blade, or a blade with ground-back corners flattens and smoothes wooden surfaces equally well. But I am bored of this much ado about "flatness", as wood is a resilient and tough material, and wooden members move millimetres or even centimetres with environmental changes. A well tuned smoother takes a shaving 0,05 millimetres thin from your 40 mm thick cherry tabletop, from a tabletop, which will swell about 0,2-0,4 millimetres in your unheated workshop overnight. Who cares then about those 0,05 millimetres deep "ripples"?
Some of you are talking about woodcraft like it was precision engineering, and that is a really serious mistake, and a sure sign, that you do not understand properly the (scientific) background of it...
The Japanese craftsman in that clip uses a simple self-made jig to sharpen a blade, and the jig produces a straight edge, not a chambered one, but perhaps it is possible to twist the blade a little as it comes and goes, to produce mild chambers. The accent is on the sideways movement (as opposed to back and front) of the blade. By the way this mildly arched sweeping movement of the blade recalls/resembles the "removing of the wire edge" in hand sharpening and honing.
Learning and practice are the core of every craft... It is a modern Occidental delusion that you can buy into that...
Have a nice day,
János
Have a nice day,
János
