After reading Alf's excellent review of the LV's I am tempted, however I note that the LV blades are secured laterally by 4 small screws which seems a great concept. The LN planes have no such refinement in fact the blades are 5 thou wider than the body, I assume this is to enable one to set the side of the blade to scrape the shoulder of a tenon when planing the cheek face. Clearly IF this is an essential requirement, adjusting the screws on the LV every time you went from shoulder to cheek cuts would be a no no. Any comments.
