Hello,
I would like to become a hand tool only woodworker and I am currently building my first workbench.
As I have a thickness planer I am deciding if I should build my workbench only with hand tools or I should take a shortcut and use a thickness planer for the opposite face and edge. I have 48 meters to plane with a hand plane ( the sum of lengths of boards only, not sum of board length x 4 sides), and I have done 80 cm so far (two boards maybe in 2-3 hours).
If I do it by hand tools, i might learn a lot more about correct planing ... new heurekas, etc. , but it will be a donkey work and take much longer. Is there anyone who has built his workbench with hand tools only? I am not time restricted, but hopefully it will not be a whole year of planing.
Another issue is sawing. My rough boards are 50 mm thick. Top is 2 m long. Legs and long stretchers are 0.8 - 1m long.At the thickness of 50 mm, how many mm would you remove by planing and how many would you use saw instead? What is the borderline for you?
Thank you.
Thank you.
