Shop counter design?
Wizer good idea on the glass ... It will have flashy things on this counter - don't worry!
Wobblycogs - the shop will be selling computers but also other other tech - our remit is anything that plugs in a computer. Focussing on cameras, camcorders, music/vid players, printers etc. We'll be selling branded PCs and laptops including Macs.
I'm really after desgin help here - not desgined this sort of thing before unsurprisingly!
Also is iron on edging up to this sort of use? Would lipping be better - would have to be much better for the amount of extra work!?
Gidon
I think for the counter, all around for sure. It's going to be high use all around. If the tables are up against a wall then I guess you'll get away with Iron-on on the back. Depends on your budget, I guess.
I'm not sure why the commercial guys haven't responded. It might be an idea to post in the General Woodworking forum with your current designs and ask for constructions advice.
Depends what you mean by tech shop, if you mean Apple type high concept stuff then I think you need to go for a completely different approach. Perhaps nice shaped wooden top on a metal and glass (or similar) unit below, something that's a little floating.
If it's a little less high concept then you could get away with curved wood, if it's a local version of Game then you could go for the more boxy approach in wood.
Beware if you're your own client, completely ignore the fact that you could build something in wood, decide what you want and what image you're after and arrive at a design. If you can then make it yourself then it's a bonus, but be prepared to farm the work out, eg it could be that you need a brushed aluminium and frosted perspex look
I don't see why a thickly lipped top has to overhang the sides, it can just sit on top of them and finish flush, a bit like this. Definately solid lipping for all of it, front corners could be solid posts with the boards biscuited into them, less fussy than a butt joint and lipping.
Infact I would do the top from say 100x50 walnut with a rebate to take a sheet of glass, that way the edges of the toughened glass will be protected and you get a display counter. You could also float the frame/top off the carcase by using a few metal spacers, bit of chrome plumbing tube would do. I've got a picture of a counter I did for a Savile Row tailors somewhere, will scan it in tonight.
Jason
Have a look at these guys counters.
http://images.google.co.uk/imgres?imgur ... start%3D18
Look at the tables in the back ground, how about making your counter based around that table, it would look great with mitred tops/legs and a set back infill on the front. You could make the edges of the top and the mitred legs in solid and use veneered mdf for the rest. would be nice in abw perhaps a bit like this.
  • Si
Thanks chaps - really appreicate your help.
I think if I get the shop tables right I'll fine tune the counter.
IB - Apple store look is closer to what I'm after.
See the end tables in this pic (sorry for pic - thought I might get in trouble for taking photos!) My floor is going to be maple vinyl floor tiles. So I'm after darker walnut tables. The shop has beams which will be painted black. Walls white (just to set picture).
Apple store tables
Jason - I don't get how you do that top (very nice by the way) - how did you achieve the thick top? If the edging is thicker than the MDF then either it'll have to overhang. Or I'd have to do something like below - with face frames - is that what you're alluding to? How do they look? I could then just lip the top. All biscuited together. Yes please post pic if not too much trouble.
Si thanks for that - I like those too. but I want the tables against the wall like my Plymouth Apple store pic above. And want to hide cables behind (see earlier pic). Is the mitred face frame as I've drawn below the sort of thing you had in mind? With the counter than I could perhaps have a panel sitting behind the face frame?
Will the designs I show below be rigid enough do you reckon.
Mitred twide / thin face frame
Mitred narrow / thick face frame
Gidon
Gidon, are you going to put leveling feet on these tables?
I think I would build the the sides anyway as boxes. Someone will kick the facing pieces and break them if they are unsupported. I would also work to avoid exposed mitered edges as they will get damaged and make your tables look shop-worn in a hurry.
Hopefully this makes the idea easier to follow. The top and the other side aren't mitred the inside of the outer side is rebated to allow the top to sit inside it and then the lip is glued on afterwards.I would make the legs boxed legs for strength and it will look better visually. The solid fronts of the leg are also rebated so that the edge of the lip that you see is only about 1/4", you can round over to the join if you need to "take your eye off it" but I think you'll be fine with ABW as it's quite forgiving.
I've seen this as a finished item and I must admit I still can't fully visualise how it's done in constuction. But it does look very nice. I'm going to nick the idea for my next proper piece of furniture.
Gidon, the tops are just a sheet of 19mm veneered MDF with two 50mm wide strips of the same glued around the edges, a bit like this shelf. The sandwich was then cut to size and as its only for use in a hime I covered the edges with flexiveneer but if you keep the total thickness under 50mm then its easier to use 50mm iron on edgeing. You can then just biscuit your sides & front panel into the underside of the sandwich, on the sideboard I cut a 2mm shadow groove to match the door/draw gap. There are some more pieces that go with that sideboard in this album
Although this piece is more traditional and one of my early jobs it shows the 100x50 frame around the top with inset glass (whole top is hinges for access). Its also possible to build the frame with a groove to take an MDF panel and lay glass ontop of this to give a durable surface like this sideboard
Wizer the beaded rebate joint is very easy. For example if you were using 25mm material instead of cutting a rebate 25x18 you cut it 19x18, this will leave a 6x6 "gap" at the corners which you just glue a strip of wood into, did this boxthat way.
Jason
Dave
Yes will be putting levelling feet on - do you reckon they will be ok in the 18mm MDF? The units are going to weigh quite a bit! I know what you saying about the mitred corners but can't see any way around this - even with Si's suggestion (if I've understood it) they be some mitre exposed?
Si
I'm still not sure I've fully understood you. It's hard to see the detail in the pics. Are you saying the top sides are rebated into the sides and the front frame piece? To then lip the un-rebated side of the sides - you'd have a very thin piece of lipping and it'd be cross grain which would be no good? I'm being slow I know!
Jason so the strips of veneered MDF go between the veneered MDF sheets and then you wrap the sides with veneer? Edens don't sell edging strip wider than 30mm? Would the iron on stuff be a little vulnerable? Guess you could lip the edges. Or have I misunderstood what you've done?!
Ok with boxes - agree does look better just more expensive and more work!!
Also a pic of how I'll have the computer section of the shop arranged against one wall.
I've ordered 9 sheets of walnut veneered MDF - yikes (I needed to get an order in for Monday delivery!). This is the current plan but very likely to change!
The reason it's modular like that with each table around 1.2m wide is because it's easier to build and I can change the shop layout as I need to.
The ends of the table top I'll add lipping.
And the counter:
Tables and counter :):
Am I getting there?!
Gidon
Yes, if you were using 19mm veneered mdf and machined out a 12 X 12 rebate from the side and joined the two that would leave you a 7 x 7 square to fill (running from front to back).
If say you are using 19mm solid for the fronts you can cut the same rebate in them. So glue those on and from the top and sides you see 7mm of solid. Glue in a 7 x 7 along the top edge and from the corner you visually see 7 x 7 of solid running 3 ways.
I actually would cut all the rebates in the solid oversize and then plane back.
This gives you a much more durable finish that edge tape. It does take longer but I think it's worth it.
I wouldn't make this infil this much oversize but this bit was laying around, you get the idea.
Si - thanks so much for the step by step - really helps! I get it now - I think! So the main advantage to just lipping the table tops and using a butt joint is strength of joint? Or do you think visually it's better too?
For the front solid wood I would rebate the full thickness of the wood wouldn't I? Oh - having just written this I'm guessing that's right - but what you're saying is that visually you'll see the same 7mm strip around the front and sides (and back if I bother with the back)?
Gidon
I think you've got it, you do rebate the fronts full thickness of the veneered mdf (or a little over so that you can plane down to it).
I think the main advantage is durability.
You will gain extra strength from your construction of the insides which includes the back.
If you want to talk over the intricacies PM me your number, or you can get mine from my website.
Si
I get it now, and I really like it!
*Idea stolen*
Thanks for the pics Si
Gidon, the latest design looks great, I really like the mock up you've done.
Thanks Si - that's a really generous offer. Wood arrives Monday so will no doubt be stuck very soon. Lovely website and work by the way.
Glad you like Wizer - little idea at the moment how I'm going to get this all cut up and joined together!
Gidon
