Shooting Irons
DTR
11 Mar 2011
Essex
Evening all.
I'm hoping you kind folk can advise me on shooting irons. I use my no 7 for shooting which, as far as I'm aware, dictates a straight blade. But for everything else I keep my plane irons cambered. What's the best way around this? Two blades for the no 7, one straight one cambered? A dedicated shooting plane? Or should I re-centre the camber on the stock when shooting?
Thanks for your help guys and gals.
I'd centre the camber on the wood.
The miniscule hollow you get along the length of the end isn't going to cause you a problem - if anything it's probably beneficial.
fwiw, in order of preference, I'd go:
Dedicated shooting plane - 'cos, um, well, any excuse, right?
Second iron
Driving yourself nuts faffing with centring cambers - 'cos I believe shooting boards are supposed to make life easier... ;)
I don't know why Matthew didn't suggest it, but the obvious solution is to buy a Quangsheng blade - takes and keeps a fantastic edge and is dead cheap.
Jim
Jim
There's already a Quangsheng in my no 7! 8). I think a second blade (and possibly cap iron) is my preferred option at the mo...
Thanks for the responses!
DTR":2exd83u3 said:
Jim
Why would you need a second cap iron - I can't see a #7 blade having enough camber that the cap iron wouldn't be interchangable.
BugBear
BugBear
I could of course use the same cap iron, but a second one saves me the fuss of changing them over every time I want to shoot something.
Plus it gives me a good excuse to try one of these Quangsheng cap irons that everyone's been raving about :twisted:
