now that's a back handed compliment to a very subtle gloat :lol:
i think.
actually rob, the end stop is a little misleading, and may have been the cause of more problems than i expected before i screwed it down.
the mess at the edge was due to me cleaning it up with a chisel to give it a kind of under cut at the bottom edge. i think because i had moved in the wedge, it was not vertical, and may well have been causing some of the problems.
as for the latest shavings i must agree with you , but am happy that i can produce them since much of the earlier stuff was dust. i need to set things to be somewhere between the two.
next step may well be to try and check out mr charlesworths writings and dvd's to see whether i can make things both better and easier.
thanks again
paul :wink:
