Hi guys,
First post so be gentle. Quick background. I am an engineer (electronics/telecoms) relatively competent DIY guy, fitted my own kitchens and bathrooms etc.
I have enjoyed tinkering away in my garage during lockdown, making a workbench, French cleat wall and drill table, and a few other bits, and it's given me a bit of a wood working bug. To make a bit more space I would now like to build some overhead shelves/cupboards to free up some floor space and I would love some advice or help on their construction if possible.
15 years ago I made a crude attempt as can be seen in the dead space above my garage door. Ideally, I would like to carry that along one side eating into about a 1/3 (80)cm of the width of the garage roof width. (where the green baskets are hanging and a bit lower). My aim long term is for me to make some doors and for them to look reasonable, but for now, it needs to be a functional space to clear some space which I can add doors to in the future.
The rafters are spaced roughly 50cm apart and I intended to hang down some supports from these, as in the crude attempt already there.
The total length will 3.6m, depth 80cm, height from the ceiling about 35-40cm
Full length…I intended to brace the back along the wall with CLS, the same at the front of the shelves and maybe one more support in the middle if needed? Covering the depth roughly of the green baskets (80cm).
The rafters are spaced roughly 45cm apart and I intended to hang down some supports from these, as in the crude attempt already there.
Q1 Lengthwise, can I span 2 rafters wasting less space on the uprights, I guess that would need a middle full length.
Q2 what timber / CLS do you recommend for the frame.
Q3 To keep the weight down I intended to use 12mm chipboard for the shelves.
Q4 is there a better way to install the hanging support as I did years ago?
Q5 As I will be stuck with a void under each span/shelve, could I increase the height of that timber and create some boxes underneath that pivot down (in the future)?
Sorry for the waffle, it's way harder than I thought trying to type and explain something. I have included some pictures which hopefully will make it a bit clearer.
Please feel free to insult and modify my plans, I am open to anything.
Thanks in advance
Chris
PS the cable hanging down is dead!!!
Thanks in advance
Chris
![IMG_20210113_164914.jpg IMG_20210113_164914.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/81/81804-IMG-20210113-164914.jpg)
![IMG_20210113_165925.jpg IMG_20210113_165925.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/81/81805-IMG-20210113-165925.jpg)
![IMG_20210113_165111.jpg IMG_20210113_165111.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/81/81806-IMG-20210113-165111.jpg)
