MikeW
Hi Paul,
The LN 4 1/2 and the LV LA smoother were both more than flat, at least on a granite reference plate they both produced an even scratch pattern right off using 320 wet/dry paper.
The LV #6 which has the frog as part of the sole was actually proud (stuck below) the sole of the plane by just enough that it produced a scratch pattern that revealed it was alternately hitting the toe and the heel while hitting the part of the frog that is suppose to be level with the sole.
But, it only took maybe 5-10 minutes tops starting at 80 and going up through the grits (120, 180, 220, 320) to produce an even pattern on the sole.
All that to say, if mine had been ever so slightly above the sole *and* using first 320 grit paper the rest of the sole had even scratches I would have stopped right there, disassembled the plane, cleaned it well, lightly oiled it and put it back together.
In other words, as Derek said, directly behind the blade is not terribly important.
Have fun!
Have fun!
