niall Y
Well, push this thread along ,in a direction it might not wan't to go - Does anyone else remember the use of 'Neats Foot Oil' for oilstones? The only time I ever came across it was in my school woodwork room, eons ago.
Don’t know why - you can buy a tool for killing trout when fly fishing,, now if you said that about a carp I,d be upset as when time permits I go carp fishing-and yes hours and hours of waiting for one to take my bait , a decent battle to get it on the bank-quick photo and it’s returned safely back to the water . My son gets really upset about this ( he has autism) he just can’t understand it’s all about the challenge.I got a load of grief on a fly fishing forum, when I said I bash the pike I caught on the head and ate them with chips and peas.
I thought it was now a fishing thread lol could discuss how to correctly sharpen hooksWell, push this thread along ,in a direction it might not wan't to go - Does anyone else remember the use of 'Neats Foot Oil' for oilstones? The only time I ever came across it was in my school woodwork room, eons ago.
Smoked haddock with parsley sauce?I'm with @Adam W. If you go to the trouble of catching it then you should eat it. Same with when I bow Box hunting, If I get something it goes in a pie or sausages (fresh and cured), otherwise don't bother.
OOH just had an Idea, smoked fish sausages. Why have I never tried to make that? MMH yeah with a nice smokey herby sauce, yum
The old chippie I worked with decades ago told me was commonly used when he an apprentice.Well, push this thread along ,in a direction it might not wan't to go - Does anyone else remember the use of 'Neats Foot Oil' for oilstones? The only time I ever came across it was in my school woodwork room, eons ago.
I haven't and nor do I.... ( he has autism) he just can’t understand it’s all about the challenge.
Veritas deluxe honing guide imho as it’s almost a complete set ,, covers small tools chisels and plane irons upto 2 1/2 inch if I recall, gives you more angle settings than you will probably need , skew jig available separately and a couple of others . In use it’s pretty foolproof which is why I like it. Oh and with the deluxe you get a camber roller , also they are interchangeable so you just have to set your angle and off you go .Agree that sharp tools are very important to us woodworkers but it has to be less of an issue if you are power tool biased and not handtools because machines like P/T 's can have disposable blades wheras a decent handplane has to be kept razor sharp. I would also say that it is the outcome that maters and not how you get there so if a sharp tool can be achieved using more modern techniques than traditional does it really mater.
One question, how many people use the so called scary sharp technique for their chiesels and what do you use to hold the chiesel as I will need to look at either sharpening one of mine or getting it sharpened soon?
Sounds good, but bear in mind you can do all those things and more, easily, without any sort of jig at all.Veritas deluxe honing guide imho as it’s almost a complete set ,, covers small tools chisels and plane irons upto 2 1/2 inch if I recall, gives you more angle settings than you will probably need , skew jig available separately and a couple of others . In use it’s pretty foolproof which is why I like it. Oh and with the deluxe you get a camber roller , also they are interchangeable so you just have to set your angle and off you go .
That's how it looks but jigs are problematic - mainly the need for a flat stone, which leads on to all that stuff about flattening which modern sharpeners go on and on about. Not necessary freehand.Surely a jig is the failsafe method,
Not that difficult and doesn't need to be that precise. About 25º for a grind and a bit steeper for finish to the edge.not having to hold something at a precise angle.
Norton IB8 is best starter.An oilstone is going to be a lot easier than using different grades of paper with the scary sharp so will look at whats around.
Thats about it! Coarse side at about 25º, fine side about 30º.Hi Jacob
So with that stone I assume you just use the fine side for putting the edge back on and the courser side if it needs more removed in order to put an edge back on. I am also assuming you use honing oil on an oil stone and water on a wetstone, but saying that I do recall a toolroom that used a white cutting fluid on a pink wheel when sharpening end mills.
