sploo
Somewhat extinguished member
Agreed. I usually wipe the end of the tool with a marker pen, and then a quick pass on the (in my case) Pro-Edge shows I've removed the smallest amount of material sufficient to sharpen the tool, and back to the lathe.There is another compelling reason for using a jig - economy. Why wear away a forty, fifty quid or more tool two or three times faster than you need to? If your grinder is mounted to a bench or board, find the perfect grind ......... your perfect grind, not someone else's ......... and glue a block at the required setting length. One gentle pass across the wheel and the job's done - the angle is exactly the same as it was before. You remove next to nothing. You might be the g.o.a.t. freehand grinder, but you cannot do that.
View attachment 158925View attachment 158926
Or it would be... if I'd had time to use the lathe in the last few years...
