Just when you thought this thread was dead I'm going to drag it kicking and screaming back into the daylight and probably make myself look an eejjiit again.
So the little Metabo hand grinder turned up today. The wheel is shot to pieces but I'd kinda guessed it would be. It'll make a nice tea coaster. Other than that its in remarkably good nick. I'll do a little rust removal on the moving parts, a quick oil and leave the rest alone. Does anyone have a recommendation for a (tiny) 3" wheel to substitute for the stone original? I was thinking a honing wheel rather than a grinding wheel. Any ideas what I need to be looking at?
Here's the laughy part.
I bought the Lidl sharpening wheel. 15 notes. Worth a punt? I picked it up and put it down a few times I'll admit.
Then I thought sod it. I'll have the receipt if it packs up mysteriously in an electrical fashion :-" .
Tried it on a no 6 plane blade that was
rotten and needed about 2 hours of wet and dry grinding.
It has a little plastic jig with magnets to hold your blade and you can set it to a required angle. Proof of the pudding is in the eating as they say.
Well, here's the thing. The bigger plane blade won't be accomodated by the guide. it won't travel far enough. so there's about 7 mm it just won't reach. In for a penny I thought. I can grind the rest out later. So, where angels fear to tread how do fools who rush in find it?
Well actually; alright.
Using the guide is a non starter. It's as flimsy and rubbish as you'd expect. It angled the blade okish tbf. I got an approximate 25 degrees. But start sliding it and you're off to hell in a handcart pretty fast. Non starter. As rubbish as you'd expect it to be. Tosh in fact.
So why's it alright? This is a two bob bit of kit. It's not going to compete with a proper sharpening machine is it? Well. here's the thing.Because it's a multi purpose sharpener. It has various plastic attachments. The chisel/ plane at a stretch one, a drill bit one and a knife scissors one. All a bit shoddy. But it has a little motor but the wheels (you get a spare), are made of sparkles and fairy dust.
So you remove the naff plastic guides, toss 'em. Then you get a bit of timber cut to the right angle and affix that bad boy to the aforementioned. Diamond grinding wheel for 15 quid. What next at Lidl? Make your own Spaceshuttle for a fiver?
This'll probably last as long as the Lidl Shuttle but for occasional grinding? Fair play. Slowish speed and thin wheel maybe helped to dissipate heat. No over heating of the blade at least to my inexperienced eye. Decent removal rate and not too aggresive. Good catch I'd hazard.
Cheers!
Chris
