Robbo3
Your welcome. Just passing on the kindness shown to me by Steve Maskery. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Robbo3":1p21fp8b said:Bob, this any good? As it's a #1, I think it's for English chisels whereas #2 was for Japanese.
Hi Bob, just spotted your mortice chisel thread. Had sharpening prob myself just recently. Been using same (Japanese) set for years just occasionally fettling the auger but not much attention to the chisel, but needing attention now. Sharpened the chisel very easily and cheaply with two diamond cones from Axminster - drill press - chisel in a hole etc to keep accurately aligned in woodwork terms if not precision engineering.Thanks for further replies.
Re hardness, I was thinking the chisels couldn't be very hard if they can be reamed with the type of tool Robbo pictured. Eric is right that the corners of the chisel in my pic have rolled over - when I've got it sharpened I'll give it a workout and, if it happens again, re-harden.
T.......
Hi Nick. I measured the one Robbo3 so kindly sent me using a digital protractor. I got 75.2 degrees across opposite cutting edges (ie total angle of cone) and 142.3 degrees between the parallel part of the reamer and a single edge. These are consistent within 0.1 degree (if my trig is correct!) - given the difficulty of lining things up to measure by hand I'm guessing it's 75 degrees.I realise this is an elderly thread but it seems the most relevant to my question: Could someone who is in possession of a Clico sharpening reamer for English pattern chisels kindly measure what the angle is?
I acquired several Japanese pattern chisels and augers with my elderly Sedgwick and they are easy to keep in good condition. A pair of diamond sharpening cones from Axminster are a perfect fit for the internal bevel on the chisels. I also have one 5/8" English pattern chisel. It's not worth trying to buy a Clico sharpening set even if I could find one (may as well just buy a new Japanese pattern 5/8") but I thought I would have a go at modifying a cheap conical aluminium oxide wheel to the correct angle, which isn't obvious from inspection of the somewhat abused chisel. The photo sent by Robbo3 earlier in the thread gives an idea, but a measurement taken from the actual reamer would be ideal if someone could oblige?
N.B. I don't know for sure that the chisel is a Clico - the first letter is C but the rest have succumbed to patina and polish - but Clico is the only sharpening tool I've heard of so hoping they are all similar.
Thanks in advance.
The original design was intended to be used in a brace, not a battery or power drill, so would generate very little heat.How do you keep them cool when using, I find I get tremendous heat build up. And I have seen chisels others use and they can be very discoloured with heat,
