Phil Pascoe
Sharpening on wet and dry is another one - I was doing it forty years ago.
D_W":2uexf3pa said:rafezetter":2uexf3pa said:David Charlesworth invented it
Perhaps with the exact set of devices he uses, but the "lift" has been done with freehand sharpening for a long time. It's especially popular on moulding planes from the hundred or so that I've bought.
my friend george in the states has done this freehand for at least 60 years. "lift" is his term.
Methods are discussed here all the time but what beginners really need is to understand the result and not to choose a method without understanding the result and standard they're looking for because it takes little time to find something that won't fit your method if you stick with the hobby.
I figured out about four weeks ago that I can sharpen the flat face of a beading plane with a buffer instead of a stone and suddenly they will go any direction on a board without tearout.
It will not become the DW method for rounding over the very tip of a beading plane because....
.....I'm sure it's been done in various ways for eons.
Mikegtr":28u4fz2j said:I am not to good at sharpening chisels & planes. Your expertise most welcome. I have done a bit of homework on the subject.
My question is: Which of the following 3 methods would you choose to sharpen?
a) Tormek sharpening system--is this the best method?
b) Wet & Dry paper on a tempered glass plate? --thickness of glass?
c ) Diamond stones?
When 'stropping' which side of the leather would you use to strop?
Many thanks.
dannyr":3e02q60u said:How many of the five would be left standing?
