Peter Sefton":37kbeymu said:
Has any one got much experience of using the Shapton stones? If so how have you got on with them?
One of my past students has some after seeing Rob using them, we have access to them and I have thought about putting them on the website but would like to hear from long time users for their opinions.
Cheers Peter
These are the views of a beginner - I've only been at this woodworking lark 18 months now - so they should perhaps be treated with caution.
I have a set of Shapton stones plus holder as offered by Dictum. The stones are 1,000, 3000 and 8,000. I also bought a 500 stone for rough work but once the edges were sorted out it slipped into redundancy. I had previously had a Cerax 1,000/6,000 combination stone. I'm much happier with the Shaptons because while the Cerax (which worked well) required a 10 minute soak before use, I only have to spray the Shaptons with water and the soak time is the time needed to set up my Veritas Mk II guide.
The results seem, to my untutored eye, to be tip top and consistent. A2 steel is dealt with very quickly indeed and one of the upshots of this is that as my confidence in the system and my ability to use it have grown, I am now sharpening much more often. It really is just a quick job at the end of a session.
I'm not sure that the 8,000 stone is absolutely necessary as the 3,000 seems to produce a pretty sharp edge and from what I've read on here the 8,000 "effect" will be worn off after only a few strokes of the plane. On the other hand as so little time is needed to put that edge on, why not?
I realise I might get my head ripped off for having this kit (particularly the guide) but in my defence I offer the following: I know no-one who has the skills to teach me and as such have to learn from books, DVDs (thank you David Charlesworth and Christopher Schwarz) and the internet. I'm absolutely sure that it is a lot more craftsmanlike (and cheaper!) to sharpen freehand but without a tutor one needs all the help one can get. Therefore I can honestly recommend these stones and perhaps some sort of guide system to any other beginner. (For what it's worth I find that spokeshave blades are a doddle to sharpen by hand but I wouldn't dare to try to put a secondary bevel on them by hand.)
